aihchris107's avatar
aihchris107
Generator slide
Slid out the front diesel generator slide as usual to lubricate. The coach was sitting at a slight incline to the rear and when I slid the slide back it closed faster than usual. I cannot get the slide to pull back out. The handle and cables to release the unit work fine but it will not budge to open. This is on a 2011 Monaco 40PDQ Knight. Any suggestions? Thank You, Chris S
  • Finally fixed the generator slide. One of the locks was jammed. persuasion with a pry bar fixed it. Now is all good to go. Thank you, Chris S
  • Something jammed. Prybar or hammer to get things moving forward again. Gently.
