Fauxqui's avatar
Fauxqui
Generator won’t start
All batteries are fully charged. When I push the generator start button all of the power goes off. I can start the generator after I start the truck and everything seems to work well. When I turn it off everything continues to work. Is this a simple fix?
  • The generator starts when I push the start button on the generator but not the inside switch. When I push the inside switch all the power goes out.
  • j-d's avatar
    j-d
    Explorer II
    By all means check wiring and connections. Be sure to check GROUND connections as carefully as you check the Positive. We've had a couple recent cases where the Ground Cable at the Generator was the problem.
  • If you are plugged into shore power and the lights go out when you press the start button there is a chance that only corroded cable ends at the battery are to blame.
    If you disconnect from shore power and the slightest load causes the lights to dim or go out, then it would be bad batteries or batteries that are not being charged.
    Go pull the shore power plug and see.
  • X2 sure sounds like a battery problem, whens the last time you checked the water in them? cleaned the cables an post.first place I,d start.
