ktmrfs
Jun 26, 2023Explorer III
Willie Jim wrote:
I'll try disconnecting battery. I see no circuit labeled battery charger in the breaker panel, guess it is powered through the main breaker.
NOPE, Main breaker only connects to the sub breakers. More than likely the charger is on one of the other breakers, likely one of the outlet breakers.
30A panel from what I've gathered only have 5 breakers per code. AC requires dedicated breaker, So does WH, Usually MW on it's own, that leaves 2 120V outlet breakers and the usually tie the charger to one of those.
Smart thing to do is to ditch code, add another dedicated breaker for the charger.
