Grit_dog
Jun 27, 2023Trailblazer
Mike134 wrote:Willie Jim wrote:
I'll try disconnecting battery. I see no circuit labeled battery charger in the breaker panel, guess it is powered through the main breaker.
If you do that than all the 12V loads will need to be powered from the generator via the 120/12V inverter.
If you could disconnect the inverter, then any 12V loads would be supplied by the battery.
Oh boy….
