_en_Plain_Air_'s avatar
Oct 22, 2016
Geo Method question
I have wanted to try the Geo method for the Black Tank. The instructions I have found on line say to dissolve water softener and detergent in hot water and put in black tank. I heated on the stove top water with water softener pellets and laundry detergent until it was dissolved, then let the mix cool down. As the mix cooled, the sides of the pan developed a pretty thick 'build-up' of film that I think would obstruct the holding tank sensors, thereby defeating the purpose. Thinking the soap was the problem, I tried dissolving just the water softener pellets and waiting for it to cool down. gain, the heavy build-up on the sides of the coolpot. Neither solution felt 'slipery' like very soft water, as I would have expected based on the description of this method. I have NOT dumped any mix into the holding tank. For those of you with experience in Geo method, is this your experience? Are the water softener pellets (dissolved) the right water softener? Thoughts? Thanks!
