korbe
Oct 19, 2014Explorer
After I drain the water heater and with the plug still out, I pump the pink stuff toward the tank just for a second or two to fill the short section of line at the tank. I will then switch the bypass valve and I am done with the tank except I will place the drain plug back in a couple of turns to keep out things. I also tie a bit of red flagging on the exterior tank access door to remind me that the plug is not tight.
