Harvard's avatar
Harvard
GFCI and an Open Ground
Given: A 120 VAC GFCI supplying power to a 30 AMP RV. The RV has one problem, the 3rd Prong Ground wire at the 30 AMP plug is not making connection. (The RV chassis is floating because there are no other sources for a ground conduction path.)
Q: Will the GFCI trip because of this "one and only problem", an open ground?
I am guessing NOT.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 11, 2025
