time2roll
Nov 01, 2020Nomad
Check your neutral and ground bus in the RV are separated and only grounds to ground and neutrals to neutral. Check for similar issue in your transfer switch. Keep the 50 amp breakers off. If there is no visual issue you will need to start disconnecting components to isolate the issue. Divide and conquer.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
