MrWizard
Nov 01, 2020Moderator
Circuit breakers even the 50 amp main
Only open the hot leads, not the neutral
Everything ok on generator
Seems like you have a neutral to ground leak , between the automatic transfer switch and the RV 50 amp male, could be the doggone adapter for your shore cord, could be the shore cord 50 amp male plug
Could be a loose connection from shore cord at the ATS
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
