jkwilson
Nov 01, 2020Explorer III
The problem is almost certainly a ground/neutral connection at the transfer switch as time2roll said. A GFCI. will also trip on a ground/neutral connection downstream, and transfer switches are often miswired. The breaker won’t affect this as it doesn’t disconnect the ground or neutral.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
