Land_Yachters
Nov 02, 2020Explorer
OK, in an effort to share our experiences and make all of us a little smarter, I will try to share a pic of what I found when changing connection to a different outlet. ****, I was using a cheap 30 amp/15/amp adapter and saw the ground lug broke off in the extension cord. I think that may be the culprit. Lesson learned..
Look for the weakest link
Look for the most obvious and easiest to fix
I couldn't find another adapter locally, and had to get one from Amazon
I will let all know if this is not issue>
Thank you all
Thank you all
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
