danwelch's avatar
danwelch
GFCI question
Our Dometic refrigerator is popping GFCI breakers when it runs on 120 volts. I pulled the heating element and it has three leads, one of which is the ground. Connecting these directly to a GFCI circuit at home, the GFCI pops after about a minute – just like at the campground. If I reset the GFCI, it will pop again immediately - until the element cools down. This is very reproducible behavior. So I am replacing the heating element – but I am very puzzled!
My mediocre electrical knowledge would suggest that the energized element is shorting to ground (the element casing) once it heats up and expands. However – here is the odd part – my Fluke electric meter says otherwise. The element has two white leads and these ohm out at 102 ohms. Spec says 104 ohms - excellent. The meter shows NO continuity (infinite resistance) between the white leads and the ground wire - even after the element is heated up and the GFCI is popping. The ground wire and the outer casing of the element are connected – near zero resistance. (That is appropriate.) So, what gives? Why is the GFCI popping?? Any ideas are welcome!!
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 29, 2026
