rerod's avatar
rerod
GFCI trips when Norcold N641 on AC. Only have 4 days to fix
I knew more gremlins would try and spoil my trip in less than a week.
My GFI is tripping when I run my norcold N641 on AC. I don't have a ice maker.
So I assume its the heating element? How do I test it, or any other tips? I sure hope the LP side works, or I'm hosed once again.
Thanks!
  • If you have a built-in ice maker the water from mine was leaking and would trip the GFI. I fixed the leak and no more trip.
    It should work on propane until you can fix the AC issue.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
