djpetrou
Mar 19, 2014Explorer
Ok, Let me clear up a few things.Obviously the GFCI circuit is 120v.
IF I am plugged into shore power it works, If I am unplugged it does not work. (non of the 120v circuits obviously will work)
I am the only owner and this does not have an inverter.
If I am plugged in the shore power and the GFCI circuit breaker switch on the Power dist panel is turned "ON" over a short time the lights go dim, the fans slow down and the battery is also drained.
IF I turn off the circuit breaker (at the power dist panel) for the GFCI's then everything returns to normal. The battery charges back up and the camper runs like normal.
Also, if I remove the battery and charge it in the garage it will charge fully and hold a charge.
Does the clarify the situation?
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
