djpetrou
Mar 19, 2014Explorer
myredracer wrote:
What about the voltage level on your shore power? Is it possible that if that is already low and then when you plug into your GFCI recept., you are dragging the voltage down low enough that the converter can't charge or trips out?
Are you plugged into a pedestal at a CG with a 30A cord or at home and connected with a 15A extension cord?
This is when plugged into a 30A Ped.
Also the GFCI plugs have nothing plugged into them when this is happening. So. IMO there should be no draw.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
