tenbear
Mar 19, 2014Explorer
I would start disconnecting wires and see what causes the problem. Disconnect the wire at the CB and try it. If it is ok then, disconnect the wire at the GFI. Continue until the problem exists with the wire disconnected. Actually, I would use a clamp-on ammeter but I am assuming you don't have one.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Mar 31, 2026
