westend
Mar 19, 2014Explorer
Please, post back with your findings.
This is an atypical problem as powering anything that is AC inside should not cause the battery to drain. When the circuit breaker is powered, the lights may flicker but should remain at full illumination if the rest of the DC system is in order.
The use of a multimeter in this situation would reduce a lot of the work.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Mar 31, 2026
