rockhillmanor
Feb 23, 2017Explorer III
There is a breaker for the GFI inside the converter.
Even if it does not look tripped flip it off and then back on. If its not clearly marked turn 'all' the breakers on and then back on. Those breakers just don't always click off all the way, I've had that problem.
The other problem can be a bad GFI. These darn things look like they are ok and the switch goes on and off but they are broke. They get tired and need to be replaced.
I still bet its the converter breaker though since both are not working.
