wa8yxm
Feb 24, 2017Explorer III
Common "none of my GFCI" causes
If none of them work, first check the GFCI itself, is it "Tripped", If so reset, does it trip again,, See below.
Now check the circuit breaker feeding it.. Is it tripped, Reset. If it trips again, see below
NOTE: in some cases the Circuit breaker may be the GFCI...
NOTE 2: IF YOU HAVE AN INVERTER... Then you have one of two configuratrions
Factory installed inverters typically have circuit breakers,, usually 2, sometimes more. on the inverter itself.. Now modern design practice is to place them on the rear where you need a flashlight, 4 hands and a mirror to find 'em so you can imagine my surprise when I went to help a fellow RVer and they were right there on the front in plain sight.
After market inverters.. May be like that,,, Or they may have a SUB PANEL inside the RV, usually near (mine is behind) the main breaker panel.
Tripped breaker prevents reset
Finaly note before we get to "Below"
A GFCI that trips immed on reset .. the sound is different than a "no power" attempt to reset,, Kind of a double click sound if it's tripping.
Below
If either the circuit breaker or the GFCI outlet is tripping.. First UNPLUG EVERYTHING that is plugged into a GFCI outlet.. if the Fridge does not work UNPLUG it (Plug is outside in the fridge access compartment)
If this fixes it plug in one at a time till CLICK it stops (HInt a night light in any affected outlet will show you quickly when it clicks)
If a GFCI still trips with everything unplugged... Check 1st the patio outlet,, Often the seal crachk, i tfills with water, and CLICK goes the GFCI.
If any GFCI outlets are in slides
under the slide are two junction boxes... I've heard of one (or both) of them getting filled with water and .. See last paragraph.
Below
