RoyB
Aug 31, 2016Explorer III
I would say NO based on this spec sheet... It shows the Inverter as a MSW TYPE inverter and the battery that is being charged while in high sun is a very small battery to operate a CPAP machine very long.
It appears the YETI 150 is more or less a good power source unit using solar power that is used to re-charge things like USB port, cell phone and computer batteries etc...
I would want some extra power to make sure the CPAP machine would run the whole night without any problems.
YETI 150
Appliances that uses motors and electronics do not do well being run by MSW type Power Inverters - especially the cheap built version AUto Parts stores Power Inverter units.
I do not have any experience with the CPAP machine but recently was talking with AIMS Inverters Technical folks about their 600WATT PSW AIMS Inverter performance and they brought up the fact that this unit solves the problem alot of their users of the smaller PSW Inverters running the CPAP machines. I assumed they was talking about the popular 150WATT and 300WATT PSW Power Inverters.
I think your best bet is to get a CPAP machines that runs from both 120VAC and 12VDC or at least get a medium power POWER INVERTER like the AIMS 600WATT PSW Power Inverter (AMAZON) that states in their description being used with CPAP machines.
Another issue that is discussed on the forums is using the 12VDC 8AMPS socket that is associated with the BAT WING Roof OTA Antenna panel. This would not be a good place to plug in a 300WATT and UP Power Inverter to use. You would want to connect directly to the Battery Bank terminals and then run an extension cord from the remote Power Inverter Installed location up to the bedroom area where you are sleeping using the CPAP machine.
Being a somewhat medical thing that is required to work for heath reasons you want to beef up on these things to insure great performance.
Would not be a good idea to run out of battery power at midnight or sooner on a poorly designed power setup with something as important to you as the CPAP machine is.
Need to check your CPAP power specifications before setting up any power sources for it.
Just some of my thoughts
Roy Ken
YETI 150
Roy Ken
