cannesdo
Feb 15, 2017Explorer
SoundGuy wrote:cannesdo wrote:
My natural gas detector is chirping. I know the batteries are on their last legs...Time to start shopping. I have four 12V and want to replace them with four 6V golf cart batteries.
I'm sure it's your propane detector, which will have have an expiry date listed on it that indicates if it's past due for replacement.
As for batteries the key IMO is to match the batteries you buy to the charger you intend to use to maintain them ... don't do that and you'll quite probably be replacing those new batteries again much sooner than later. :M The first step therefore is to identify the charging characteristics of whatever charger you use and if it's not capable of properly charging the batteries you intend to buy then you'd be wise to replace it as well.
Thanks...I have a Freedom Combi unit with charger that can be set to any battery type.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
