time2roll
Feb 15, 2017Nomad
cannesdo wrote:If you wanted to replace a single battery you should separate and see which one drops and which one's hold the voltage 12.65+. Or you can separate just to satisfy your curiosity.
I'm at 12.56v now with all four batteries and it's been four hours. Dropped just .04 in the last two hours. Need to know if I should disconnect them from each other though...don't really want to do this again.
Assuming you are replacing the whole set it does not matter which is bad. Always best to swap them all.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
