evy's avatar
evy
Golf cart batteries vs storage vs charging??
Hi everybody!
Quick question for you today.
I'm building a campervan conversion out of a Ford E250 high top van.
I'm new to all of this and it's my second year of building this thing (part time)
I live in canada but I order a lot of equipment online in the USA and I have it delivered near the border then I go down to get it.
I did that a couple of times now and I saved a lot of money (even if the exchange rate is not good for us)
Most of the equipment is just sitting there in my garage with my campervan waiting for installation.
Among the equipment, I have two 6 volt GC2 golf cart acid batteries that I bought at Sam's club in July (summer 2016)
https://www.samsclub.com/sams/duracell-golf-car-battery-group-size-gc2/prod3590228.ip
I wanted to know if it's ok to leave them there until I hook them up? or do I need to put a trickle charger/smart charger on them?
My garage is not heated but it is connected to the rest of the house so it's around 50deg F most of the time, the coldest it will get is around 40deg F.
Thanks for any advice!
  • Not in my opinion. I have one of those and could not get the same reading twice.
    I like the OTC4619
    https://www.amazon.com/OTC-4619-Professional-Battery-Hydrometer/dp/B0050SFVHO
    Just do not throuw out the packaging and store it in there and Fragility is not an issue.
  • Yes, they have lost some capacity.
    Batteries self discharge, and they have shelf lives.
    They self discharge more with age, and with higher temperatures.
    YOu should fully charge them and then Ideally perform an Equalization charge, if the cells do not all read 1.275+ on a Hydrometer.
    Equipment and processes for doing this have been discussed in depth dozens of times on this forum.
    I have a freind who once purchased high$$ AGM batteries and never put them into use. Years later, he kept muttering they were brand new and never used, yet the voltmeter and charging sources proved theses new batteries were sulfated and worth only their weight in lead.
    Sadly this did not prevent him from repeating the unwise decision, and I go there with my charger every month and top them up, but they are now over 2 years old. 800$ worth of top quality battery wasting away, slowly. They'd be near useless if I did not top them up regularly. they are due now.
  • beemerphile1 wrote:
    ...they have been sulfating ever since.
    I'm guessing that's a bad thing :S but how bad? Did I damage them in a way that they will have less cycle life?
  • Yes, you need to charge them and keep them charged. They probably were not fully charged when you bought them and they have been sulfating ever since.
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 23, 2025
