mike-s
May 14, 2017Explorer II
pianotuna wrote:I take it you've never busted into a Master style laminated lock by simply grinding off the heads of the rivets which hold the laminations together, then delaminating it. Way easier than trying to cut the shackle.
The locks have a hardened steel rod that is loose inside the center of the pin. When you try to use a cut off wheel the rod just spins. I think it is too tough for a bolt cutter as well. That leaves a torch as the only solution for the lock part.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
