MrWizard
Aug 30, 2017Moderator
The primary thing is the ability to program almost every single setting
Max charge voltage , boost time duration, low voltage return to boost mode, float flat voltage, i have no way y to know if it's more efficient aka (less internal loss)
But it is the most user adaptible controller i have come across
Mine is set so low voltage return to boost is the same voltage as float
If the voltage drops to lie set point , when i use the MW then, it goes right back to boost mode, aka set charge of voltage 14.8 , and not set around in float mode
You may not need the ability to do this, for me this is very helpful
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
