CarArt's avatar
CarArt
Explorer II
Sep 06, 2018
Gray tank plugged, limited options
Yes, I know it's been beaten to death but please bare with me.
70, disabled, on SS so on a budget. Not the issue, just sayin'. Yes, I'd love to have Joes RV Specialist come out but I need to try something on my own first.
My gray tank will not drain, says full, believe it since if I add water to kitchen sink it leaks onto the ground(?) from beneath RV(covered underbody so I can't see from where). I've endlessly searched the options but it seems with a full tank, not being able to move my RV out of the parking space, this creates some issues. Tried a snake, down the vent tube too. Not sure it gets where it needs to be because of turns in the plumbing. Thinking it's simply partially full of sludge since the valve seems to operate ok and I've replace the black one myself so I know what goes wrong. I'm fairly careful about what I let go down the sink but we all know sooner or later likely to have an issue. I have screens in my kitchen sink but I bought it used so...?
To the meat of my question-
I'm considering trying a variation on something I've seen but that I haven't really seen anything about specifically. And I've looked. Attaching a garden hose to the Clear 45 Degree Hose Adapter Sewer Fitting(Main), closing 2 valves on black and bathroom gray tanks, then opening garden hose attached to the adapter and letting water pressure go up to the blocked kitchen gray tank(this valve open) and "backwash" the plug, shut off then hopefully it will break free and flow out. Probably repeat.
Obvious issues-
1. too much water backwashing and shooting up and out kitchen sink/plumbing not intended to contain pressure. yuk. Plan to just open the garden hose, watch as it fills the Clear 45 Degree Hose Adapter Sewer Fitting, shut off- see if I get the release coming back out.
2. worried about breaking plumbing/tank but again will not just open garden hose and let it run. Open/close and look for release.
anyone try this? have any "no way!", "watch out for this", "glad we're not neighbors" "Genius!"
  • anyone got any thoughts about my using a hose to backwash the plug? I saw one youtube video where no a guy did something similar, swore by the results and it was simply lifting his sewer hose and "forcing" the water to run back into the "plugged tank". My thought was that might work if my gray tank wasn't full but the weight of the water in it would likely prevent any "backwash" effect.
    Any thoughts on my idea?
  • I would run a snake up the drain. You really want to know what is going on get a camera.
    Camera $17 (this is Technology Corner sub-forum after all)
  • 1. not a new RV. yes, it's drained fine till last week. 10 yrs I've owned it.
    2.pretty sure it opens, drained VERY Slowly for a few days then stopped. The valve pull feels the same.
    3.no, wipe greasy stuff with paper towels first, almost always put soap in any water containing grease to break it up. I installed a dish washer but still the same process of cleaning. But, although my RV is in great shape, it's a 2005 and I've had it since 2008. So...
    I'm from Pontiac, born, raised in West Bloomfield. Appreciate any help.
  • Not sure I understand the problem, have no idea why it would plug like described, but I would say you've got nothing to lose except making things worse, and creating some additional mess.
    Are there any plumbing diagrams that might show an alternate access point to dump it, like a capped cleanout drain somewhere else underneath the unit?
    My Navion has a macerator pump to empty the gray tank, but if it fails, there's also a cleanout drain located near the tank along the drain pipe. I've already set it up as a failsafe, by adding a valved, capped drain plug in place of the screw in hard cap.
    Good luck.
  • Probably should start from the beginning to help others troubleshoot.
    1. I assume this is not a new rv to you. So it has drained properly in the past?
    2. You confirmed the valve is actually opening?
    3. Do you put a lot of grease/food products down the sinks?
    I would think short of a blockage at the valve it should drain even if the vent is plugged. Although maybe slow.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 22, 2025
