olympicman's avatar
olympicman
Gray tank venting problem
Gray tank vent problem:
A couple of weeks ago water backed up in the shower while wife was showering , when I returned an hour later I looked in shower with 3" of water in it I said no big deal tank needed dumped.
Now when we fill the kitchen sink with water for dishes and drain it backs up in the shower if the dump valve is closed, but drains fine with dump valve open. Thought ok vent to tank is plugged, so I removed vent cap at roof of RV and ran water down vent pipe to clear and make sure it ran clear and it did.
Clearing the vent pipe did not help and I tried stuffing a towel into shower drain so water could not come up there, filled both kitchen sinks and drained them with dump valve closed and water came up in bath sink drain. There is also a bad smell when draining sink with dump valve closed, but no smell when valve is open.
My gray vent pipe does not go straight down at the top it has 2 45 fittings to move the pipe over to miss the slide-out.
Any ideas to help would be appreciated.
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 16, 2026
