ernie1
Dec 16, 2015Explorer II
My gray water tank sensors will periodically act up as to be expected because of the accumulation of grease, toothpaste and other nasty stuff. My solution is to remove the small drain plug on the bottom of the tank and insert my homemade flusher, which is attached to a garden hose, and aim the stream of water at the sensors located at the corner of the tank. Takes about 5 minutes total and it works every time!
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 19, 2026
