Cecilt's avatar
Cecilt
Greasing EZ Lube TT axles
After having a bearing failure on my last camper when I had a shop replace and pack new bearings on my 3 year old TT I am a little skiddish about bearing failure. We sold that TT and are now in our 3rd season of using it. We have probably put 17k miles on the TT since purchased new in Sept 2013.
My axles are the EZ Lube. Keystone Outback. I had the TT inspected which is required in VA and they checked for looseness and if the wheels wobbled while they jacked up each tire off the ground. All was tight but they did not pull bearing caps(not required).
How many repack bearings regularly? Not sure why they would even dry up in a closed system of if folks just do this out of habit? My thinking is let them be. Sometimes messing around with things opens up problems down the road.
When my old one failed it was a bad job and I don't want to worry again that if I have them repacked that I won't have another failure due to poor workmanship. Should I just squirt a little grease in the fitting and call it a day? If so, what is best grease and should it just be a small squeeze of the grease gun. I know that too much grease will blow the seal and I don't want that to happen. tks
Having RV issues? Connect with others who have been in your shoes.24,336 PostsLatest Activity: Nov 16, 2025
