Fubeca
Apr 22, 2014Explorer
Fubeca wrote:
Yes it appears to work. I stuck the panels together in series just to see if it would help overcome the shoddy wiring for the test.
Under no load, I was seeing 60V 2A in at the controller and 14.5V 8A out (mostly charged battery). Under a HEAVY (60A) load, it went into boost and I was seeing 42V 7A at the controller and 25A out to the battery according to my clamp on meter.
Once I get proper wiring, and get it set up right I believe it will work just fine!
When I said no load - I meant it was charging the battery (probably 85-90% SOC) but no additional load. So it wasn't really Voc. Later I ran my heat gun on low from my 2000W inverter and it went into boost and pushed up the amps.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 23, 2026
