rhagfo
Jan 11, 2020Explorer III
time2roll wrote:enblethen wrote:I believe these are rated by code to allow to be covered in a wall without a J-box. In essence rated same as continuous wire by code.
They use the same style of jab in connector terminals on some switches and receptacles. Less then desireable connection.
Rated for different gauges of wire but may not work well with small and large wire.
Sorry I don’t even need to look, code requires access to all wiring splices. You can NOT bury in walls!
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
