ajriding
Feb 12, 2020Explorer II
The Wago is not a twist and pull, not sure where that came from. There is a lever than clamps down and the wire is stuck until the lever gets pulled up, which takes quite a bit of prompting to do - should never unhook by itself.
If you look at any DIY forum long enough you figure out that individuals are not bound by any code. Following a code will be safer, but code is not the only safe way. Individuals can take their own risk and judgment for what will work and be safe, right or wrong, the layman does not read 1,000 page code book to connect two wires together. This is a tired comment to keep bringing up every time someone works on their RV. Feel free to suggest a better way, but stop with the code references
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
