Old-Biscuit
Oct 01, 2020Explorer III
Look up the specs on your brand/model of pump
Probably lists 7.5a or 10a
Pump stopped working but started working when you swapped fuses from 10A to 15A
That is because the 10A fuse had blown
Shurflo 4008 requires Minimum 10A Fuse (7.5A full load)
Shurflo 4048 requires Minimum 10A Fuse (9a full load)
Course that is with correct wire size.....12ga recommended
AquaJet ARV & AES Series...15A Fuse
AquaJet ES Series....10A Fuse
So what is your pump???
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
