Old-Biscuit
Oct 01, 2020Explorer III
Yosemite Sam1 wrote:
Thanks everyone for the input. I'll check into those as my son promised to look into it when he comes visit us.
He also suspected the fuse is blown and it is just not apparent by just looking at it through the red cloudy plastic case. He said it is still supposed to continue working if the fuse has not blown.
Auto blade type fuse has 2 small openings on top of plastic case that are direct contacts with each side of fuse
Fuse installed......voltmeter 12VDC ---should read if not blown
Fuse NOT installed...voltmeter ohm.....should read 0 (zero) if NOT blown ----reads 1 or OL then fuse is bad
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
