Gdetrailer
Dec 03, 2021Explorer III
ForestRiverTT wrote:
Yeah all things being equal I'd like to just find an entirely new control board. If I can't I might upgrade to one that has a temperature thermostat. The one that broke only has "low" and "high" on/off function.
Consider a replacement as a nice upgrade feature and don't look back.
If you want to go down the rabbit hole, you will have to figure out who exactly made the fire place and contact them for parts. Greystone is most likely nothing more than a importer name.
Typically most companies are fairly proud of their devices so they will at a minimum put their contact info in the manual somewhere. The Greystone manuals I have found so far there is no company name or contact info which sort of forces you to go back to the RV manufacturer and see if they can provide some contact info.
I found THIS blog about replacing circuit boards in Greystones but they did not give any contact info or where you can buy boards. You could of course try to contact the blogger and see if they will give you some info.
I did find THIS post which mentions..
"Greystone fireplaces are made in China and imported by Way Interglobal, 3002 Coast Court, Elkhart IN, 46514. (574)-971-4491. "
So, you will have to contact Way Interglobal which is an importer to see if there are replacement boards..
