Hogan's avatar
Hogan
Ground Fault outlet will not trip when converter is running
NEED HELP! I have chased this problem the better part of 2 days and $300 and had no luck!
When my 2008 HHII 32.5UKTG fifth wheel is plugged into 110V. and the converter is running the ground fault outlet in the kitchen will not trip when the test button is pressed. If the converter is not running and still plugged in the test button works correctly. The converter is on the same circuit as the ground fault outlet which is a good thing.
If I remove the batteries from the system by removing the chassis ground wire or one of the positive post wires with the converter running the outlet works just fine. If appears I have an open ground when the batteries are connected and the converter is running.
I have replaced both the outlet and the converter with no change other than to my bank account.
Do I have to chase every 12v circuit checking for open grounds?
HELP I am at a loss.
Having RV issues? Connect with others who have been in your shoes.24,321 PostsLatest Activity: Sep 21, 2025
