mikestock's avatar
mikestock
Ground fault when I plug into 120 v outlet
I have no problems when plugging into a campground 50 amp outlet or when running off the generator, but when I plug into the 15 amp, 120v outlet at my storage lot I open the ground fault breaker at the box.
Turned off all the power users in the RV except the Xantrex PST inverter/converter. The inverter works perfectly when traveling. Runs my household fridge or any other outlet I need.
I'm about to go out and take my Honda 2000 and see if I can get a reading on current usage under the same conditions.
I know there is nothing wrong with the GF outlet at the storage lot since two other rv's are using it. It only opens when I plug in.
I suspect that the Xantrex may be the source but don't know how to trouble shoot it.
HELP!!!
