mikestock's avatar
mikestock
Ground fault when I plug into 120 v outlet
I have no problems when plugging into a campground 50 amp outlet or when running off the generator, but when I plug into the 15 amp, 120v outlet at my storage lot I open the ground fault breaker at the box.
Turned off all the power users in the RV except the Xantrex PST inverter/converter. The inverter works perfectly when traveling. Runs my household fridge or any other outlet I need.
I'm about to go out and take my Honda 2000 and see if I can get a reading on current usage under the same conditions.
I know there is nothing wrong with the GF outlet at the storage lot since two other rv's are using it. It only opens when I plug in.
I suspect that the Xantrex may be the source but don't know how to trouble shoot it.
HELP!!!
Having RV issues? Connect with others who have been in your shoes.24,336 PostsLatest Activity: Nov 16, 2025
