Salvo
Sep 12, 2014Explorer
Inverter generators do not have a Y or Delta winding. That means there is no neutral, hot or ground. Inverters have just two outputs, either output could be designated as "neutral" or "hot", it doesn't matter.
When bonding one of the inverter outputs to chassis, the chassis is now at the same potential voltage as one of the inverter outputs. You are now one fault away from electrocution. Without bonding, you're two faults away from electrocution. You can be in contact with chassis and either of the ac outputs and not get shocked. I like that safety margin.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
