wa8yxm
Jan 17, 2021Explorer III
Gdetrailer wrote:
A lot of "assumptions" being made..
2Kw inverter doesn't "need" 400Ahr of "battery support" (what ever THAT means).. If you mean 400Ahr capacity, you would be dead wrong because the OP did not specify just how long are they needing to run the fridge from inverter..
Well yes. poor choice of words
Xantrex recommends two pair GC-2 for a 2000 watt inverter is what I should have said. Yes it will work on less. but Xantrex recommendation for the Prosione 2.0 was 2 pair GC-2 or 420 Amp Hour. of storage
