Wikel
Jun 09, 2017Explorer
MrWizard wrote:
Have you been to one of the DIY electric vehicle sites
Have looked at the battery packs involved
As I remember it, there is more wiring
The cells are Managed by the BMS, the battery monitoring system
Your drawing is the basic hook up of the discharge path
The charging system path is more complicated overlayed on top of this, more connections and wires directly from the bms
The BMS can be just monitoring with low and high cutoff or in combination with some type of balancing (debatable if that should be done with lifepo4 or not... i.e might damage they). This discussion is beyond BMS which is another topic in itself.
