Wikel
Jun 09, 2017Explorer
mapguy wrote:
Think you want to do 6p4s. What cells and BMS are you considering?
Remember RV usage is similar to house battery systems on boats. Not really similar to EV battery systems due to the constant loads and multiple charging sources.
Take a look at the following web pages:
http://www.pbase.com/mainecruising/lifepo4_on_boats
https://www.entropypool.de/engineering/
http://nordkyndesign.com/category/marine-engineering/electrical/lithium-battery-systems/
Clab batteries 180AH 3.2v.
BMS I am still exploring but don't want to put that into this mix until the basic electrician approach is defined.
I'll take a look at the 6P4S vs. 4S6P. That does change some things even though the output is the same. Thought I had read somewhere that do P first and then S vs. the other way. It also affects in and out boards for BMS cell/pack communications and monitoring (less in and out boards at a pack level (4 packs vs. 6 packs).
Thanks
