BFL13's avatar
BFL13
Explorer II
Jul 02, 2015
Had to Lower My Solar Float Voltage-Update
Updated 9 July
Just a note for folks in a similar situation.
My usual procedure in a normal summer here with my set-up with the Eco-Worthy controller (adjustable Absorb and adjustable Float ) is to set Vabs at 14.8 and then, since it immediately goes to Float (no time at Vabs) I set the Float as high as it will go, which is 14.5 so it stays there till dark.
Somewhere not long before dark the batts are at "true full" by baseline SG, which I can tell because the Trimetric reads 15AH "over" (into positive)and this corresponds to baseline SG. Supper and evening usage of the big draws via inverter (microwave etc) keeps the batts from going on too long at the high voltages, losing positive plate and water.
Well not this year! We are having fabulously good weather, thanks to some giant squids off Peru or whatever it is, so now the batts are getting to baseline SG mid- afternoon and IMO spending too long at high voltage before dark.
So the new drill while this lasts, is to lower the Float voltage to 13.8 once the Trimetric says we are at 10AH over, which is about 3:30 pm these days. I will keep track and adjust as required of course.
The EP Solar controller I had before had a fixed charging profile of getting to 14.6, stay there for two hours, then drop to 13.8 till dark. That would be perfect right now, but with this controller, I will have to do manual resetting of the Float till the weather gets back to normal. Put it back to 14.5 in the morning then to 13.8 mid afternoon.
Lesson is---keep an eye on things and adjust as required. Solar is not a set and forget system.
  • I found it much easier to get the SG up higher earlier in the day, on Hot days on my screwy 31.
    I also found it required on those hottest days, lowering the voltage in the afternoon after less time at Vabs, Unless I wanted to gurgle them purposelessly.
    I think even if the Charge controller has a battery temp sensor, hot weather Vabs durations should also be lowered as well as Float voltages, especially if Float is set to near Vabs as a 'finishing' charge.
  • This adjustment is what can be automatic with the more expensive controllers.
  • Thanks, Fred. I want to get some gassing but not too much. You guys Down South are used to this kind of weather, but this is a tropical heat wave to us! :)
    Mex, yes. Much sounds of big bubbles happening at the Float of 14.5 in mid- afternoon. It doesn't get dark till 10 pm so it is hard to find enough usage for AH to keep the batteries at 13.x instead of 14.x till dark. Don't even need the lights on to read. No furnace! It is not fit for human habitation hardly. :(
  • Of course since you are operating at IFR but can use VFR you have actually looked to see batteries bubbling and bobbers riding high Y\N ?
  • 13.8 is plenty of voltage to keep the battery 'full'.
    More is not always better, especially if you are only boiling off water at 14+ volts. Overheating the battery plates is never a good thing either.
    Good luck with your new voltage settings!
    Fred.
