msiminoff's avatar
msiminoff
Explorer II
Sep 27, 2014
Harbor Freight Battery Maintainer Mod
I have a TT that I store at a remote location during the winter and I bring the group 31 AGM battery home with me. I have a charger to ensure that it is at 100% SOC before it gets set in the corner of the garage, but I have been looking for a float charger to keep it at the mfr's recommended float voltage of 13.4-13.6V.
I found a coupon from Harbor Freight for one of their 69955 Automatic Battery Float Chargers for only $5 and figured it was worth a shot to see how well these little maintainers perform. However when I hooked it up it was apparent that there were two significant flaws; 1) The LED power indicator would illuminate even when mains power was disconnected and 2) the float voltage was in the 13.8-13.9 range.
After cracking the case open I realized that both of these issues could be easily remedied with components I had in sitting on on my workbench…. I added a generic 1A Schottky diode to the output wiring which prevents the battery from powering the LED in the event of a loss of AC power. I replaced resistor "VR1" with a 100 Ohm 22-turn trim-pot which gives me control over the charge voltage.
I'll keep an eye on the voltage & current over the next few weeks, but at the moment this looks like a promising battery maintenance solution.
Cheers
-Mark
Diode & potentiometer installed.
The trim-pot can be accessed from outside the enclosure.
AGM Battery float-charging at 2.41mA and 13.47V.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 18, 2026
