Bill_Satellite's avatar
Bill_Satellite
Explorer II
Apr 12, 2017
Having inverter issues. (Long post)
When I bought this coach it had an inverter that was not also a transfer switch (separate charger and inverter) so there was one transfer switch that controlled the switching between shore power and generator and another that controlled the switching between inverter and no power from either shore or generator. After installing a new charger/inverter combo with integrated transfer switch I was told to remove the 2nd transfer switch as it was no longer necessary. I wired 2 incoming 30 amp 3 wire A/C connections which are on separate legs and provide 240V between the 2 hots. To wire this up I put 1 hot in the Hot 1 connection and the other hot in the Hot 2 connection with both neutrals in the neutral connection and the 2 grounds connected to the ground post. This allows full battery charging plus full pass-through of power on that circuit. There are 2 outputs and there are 2 120V lines that go into the coach from the inverter. The output side has connections for 2 hots and 2 neutrals for each line and the grounds are combined into 1 post. The problem is that after awhile, the inverter fails saying there is an A/C fault that cannot be recovered from and requires repair/replacement. The manufacturer says that this can only be caused by A/C feedback (sorry for the long story). The company has been good enough to replace it twice under warranty but it just happened again. I have not "used" the inverter as I have been parked in the same location for many months but the inverter was "on" in the software despite always having 120V power. One morning we wake up and it's showing the error. Nothing happened and nothing changed other than the inverter and the battery charger are now dead.
My first question is, what is A/C feedback and would that be coming from the A/C input side or somehow from the 2 - 120V lines coming out of the inverter that power dedicated plugs inside the coach. Second, would re-installing a 2nd transfer switch solve this problem? Again, this transfer switch would keep the 2 lines going into the coach from the inverter isolated from the inverter as long as shore or generator power was available and would only send power to the plugs inside the coach from the inverter if neither shore power or generator power was available.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    I have seen this but not how to fix it.
    AC feedback.. Means that it detects an AC power source on the OUTPUT, All power to the OUTPUT should go either through the inverter or FROM it, but never should power return to it.. I would suggest a re-wire someting like this, but I'd need to know more about your RV and inverter to "Fine tune"
    Main panel--30 amp----Inverter---Sub panel---Loads powered by inverter.
    NOTHING common between the left and right sides of the inverter.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
