tvfrfireman
May 23, 2017Explorer
joebedford wrote:tvfrfireman wrote:Did you try manual override? Press the mode button 6 times then hold for 5 seconds 7th time to enter manual override. Use regular switch to move in/out. NOTE: over current and short protection are disabled, so be careful.
I also did the system reset. It only goes and inch and then stops each time.
I have since talked to Lippert. This tech was very sharp and told me to reverse the wires to the motors and see what code blinks. He told me if it blinks 2 green and 8 red it is the motor. I put it all back together and sure enough, it is the motor. I now have to figure out the gear ratio of the motor. It is either 300:1 or 500:1. The told me the information would be on the column. It is no where to be found. Nothing is easy with RV's.
Thank you everyone for your help. If the new motor doesn't work, l will reply back after I get it together. David
