j-d
Apr 08, 2015Explorer II
If it's a Class A on Workhorse, we had a case of a stuck relay.
Also, if the vacuum to the mode select "switch" (actually a vacuum switching valve) has failed (broken hose, leaky reserve tank, bad select switch), then the system defaults to Defrost.
We need Make, Model, Year. Chassis year, not RV model year.
