Huntindog's avatar
Huntindog
Heater won't light.
I have a 2010 Palomino Sabre 30 BHDS with a Suburban SF-35F heater.
On our last trip, the heater started acting up. I wouldn't light probably 80-90% of the time. The fan would run for 30 seconds or so, and then it would stop.
I figured that it may be the sail switch, as I read here how they fail a lot. I removed the heater, found the sail switch and cleaned a little dirt off of it. It tested good with my volt/ohm meter, so I put it all back together....It doesn't work.
Not sure what else to check.
