pianotuna
Dec 08, 2013Nomad III
Hi,
What KT said and add the air conditioner is noisy. The fan in it can eventually wear out, too. I do have a heat strip.
Usually, if there is a wall thermostat it is not possible to run the furnace and the heat strip at the same time. One of my many mods was to add a 2nd thermometer that is for the furnace only. That way I can run the heat strip--and if it can't keep up the furnace will "join the team".
I'm down to running 3 to 4 thousand watts now--but temp is supposed to drop to -31 C--so that may adjust itself upwards.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 02, 2026
