MrWizard
Sep 23, 2016Moderator
i have a kill-a-watt , but its only good for 15amps max and you have to step thru
the readings
this one will show you three things at once
going to use at at the generator, so i can measure the whole rv PF with the a/c on
and also see the amps and watts for the whole RV
the readings
